Warninger said:Mine was also about 3/4 turn loose and seems more stable now. While we are on the camera subject, anyway of changing the pitch of the camera? I want it to point more straight out, not so much down. Will the software do this?
gfredrone said:Warninger said:Mine was also about 3/4 turn loose and seems more stable now. While we are on the camera subject, anyway of changing the pitch of the camera? I want it to point more straight out, not so much down. Will the software do this?
Yes 1000 -825 -825 in gimbal settings is where I have mine and it points straight out.
gmtx said:I just checked the screw on my gimbal and it sure feels like it's stripped. It turns freely and then sticks a little and then turns freely again. The gimbal seems solid though - no wiggle - so now I don't know what to think. I hate to RMA another one and I haven't even flown the thing yet!
gfredrone said:I noticed after a very jello ridden video tonight that my gimbal seems to have some play where it connects to the servo. If I grab the camera and hold the plate above it firm I can tilt the camera about a cm each way. Is this normal and something I am just noticing?
Also is anyone getting color flickering in your video? Some of the trees I filmed tonight were flickering different shades of green (the sun was behind the camera). I also had some banding across the video when the sun hit the lens at a certian angle.
Do white balance and the anti-flicker settings work while recording video?
dbcch said:gmtx said:I just checked the screw on my gimbal and it sure feels like it's stripped. It turns freely and then sticks a little and then turns freely again. The gimbal seems solid though - no wiggle - so now I don't know what to think. I hate to RMA another one and I haven't even flown the thing yet!
Stripped? And you never removed it? That's hard to believe...
I think you should proceed with caution and not assume it's not exactly as designed. I am not sure it's supposed to be tightened down all the way. Perhaps being a little lose gives the camera some room to correct its orientation without the gimbal motor firing.
After all, it's positioned as if it's meant to be adjusted...
El Rey said:Thanks for the pic. I haven't opened mine up to tighten it yet.
That screw angle looks odd - like you couldn't easily get a screwdriver on it.
Maybe it's the photo angle.
Dear DJI Customer,
Thank you for your email.
You can visit our website to see all certified dealers that can assist you in replacing this part.
http://www.dji.com/dealer/phantom-dealers/
Best regards,
DJI US support
[email protected]
