How much ground can I see?
So.... does that mean if I'm at 50 feet (altitude), I'll get a little over 100 x 100 feet of area in the view? Camera FOV is 94°.
(my music degree didn't prepare me for this kind of math :)
Old school for music degrees: Fly up to 50' and take a photograph. Observe the 4 corners of the the frame, using objects on the ground, and then measure the distance between them. Alternatively, place four objects on the ground at the corners of a 100' x 100' square, and launch from the center, and find out how high you have to fly to see all four corners! :cool:
If you studied audio engineering have a look at the section that explained how to position your near field monitors behind the meter bridge, it’s the same basic trigonometry...
Reactions: GadgetGuy
Not quite.
At 50 feet, the camera's field of view will be 90 ft x 67 ft
From 77 ft, it will be 138ft x 103 ft (assuming you use 4:3 aspect ratio)
tom sauter
