15550 feet.. Lol 31,000' and some change round tripyou went 15000 feet one way in 38 degree weather?i have gone 3 miles one way with my phantom 3 pro but not in that temp..id say you were very lucky to say the least.
Most excellent. I get weak in the knees at 600'15550 feet.. Lol 31,000' and some change round trip
If I knew how to post the flight data on here I would
That's unfortunate. I've had a few RTH and was able to steer/alter the landing point every time. Scary that this could happen.
Here you go! DJI Flight Log Viewer
Follow the instructions, then post a link back here.
The link works for me:All I see is links for Facebook, Twitter and such.. Which I don't do any of.
No, I do not fly for a living. Photography and video is my hobby. The P3S is just another addition to my other existing gear.You don’t fly for a living do you?
This morning I went 15,500' & returned to land with 9% battery..I was a little concerned to say the least. It was about 38 degrees with no or almost no wind. This is in what I would call an optional location to fly. I NEVER lost signal or video. I manually activated rth at about 52% battery. Talk about sweating bullets
I can get out like that with about 20 25% in warm weather using the DBS mod. No windThis morning I went 15,500' & returned to land with 9% battery..I was a little concerned to say the least. It was about 38 degrees with no or almost no wind. This is in what I would call an optional location to fly. I NEVER lost signal or video. I manually activated rth at about 52% battery. Talk about sweating bullets
Under
under your app menu, aircraft battery section, change your critical battery level (use caution) it's factory set at 10% to auto land. I moved min to 6%
That's awesome! I have both the CP antennae you see a lot of on ebay and I have the ITELITE installed and untested......and the amplifiers are in the mail! What's cool is that I'l be able to amplify either antenna setup - with a little modification of the CP antennae. So far, I got something like 2.8 miles over hilly terrain @ 1640'. Also using the Ohio River for scenery and navigation purposes. It's funny how the signal travels best over water. Really psyched to check out the antenna, and even more so, the amps. PS.....Can't the signal path also be improved by modding the DRONE antenna?It has the itelite antenna
I've tried numerous times to get a link. But all I see is a .txt link of the log and when I try to open it it's gibberish.Here you go! DJI Flight Log Viewer
Also the directions arent super clear, do you go thru the PC into the phone to look for log (which is what I assume) ?
