Home symbol on FPV UI screen
The iOSD for my P2 FPV setup had this nifty symbol on the interface that would show where the home location was on the monitor.
Is there such a symbol on the pilot app?
Yes. It's a green circle with an H in it on the map.
No. This was a white diamond symbol on the FPV screen that moved around based on where you turned the camera.
No. This was a symbol right in the center of the FPV screen that appeared when you turned the camera in the direction of the your home point.
Gotcha, no I don't think it does that. I could be mistaken though. The map shows the orientation of the bird though which is helpful, for me anyway, if you lose LOS for some reason.
You can select the radar display for the lower left of screen.
This shows the angle from you to the Phantom and which way the Phantom is facing.
Fimaj
