HELP - recover crash video
Kelowna, BC, Canada
I need help with recovering a video from a crash.
Yup, these reports of P2V+'s falling out of the sky are real and I can prove it.. If someone can tell me how to recover an MP4 file from the crash.
I was flying around the back yard to test the new 32gb card in the Flytrex, nothing fancy just up down circling the house to see if the new micro SD in the Flytrex was working.
I was about about 40 -50 feet away and it was about 80 feet in the air just over my house, I could see it clearly when all of a sudden all 4 light went dead, complete loss of power and it dropped from the sky.
I let out a big $%#!, then my wife - sitting in the living room - heard a "huge bang!" on the roof.
It bounced off the roof and into the front yard. Battery was about 5 feet away, camera and gimble toast, but the SD cards were intact.
So here is where I need some help. the Flytrex data on the Flytrex SD is fine but the video on the camera SD card is "can not open file". the file is there but it is a white box instead of an image for the thumbnail.
Is there a way to recover this file. I want to match it with the Flytrex data to show what happened.
Can someone please help, I'll share the crash video :shock:
Here's a link to the Flytrex data http://www.flytrex.com/mission/quadcopter-phlying-phantom-matt-lennox-40029
PS. I have extended warranty protection on my Visa that I bought it with, has anyone ever successfully made a claim for this kind of thing?
Try opening it in MPEG Streamclip (free).
2nd option is loading it in VLC (also free), but harder to export from.
Only thing I have found that wiorks is to pop the card into another FC200 camera, and it will clean up the video.
So look for another Vision or Vision+ owner to help.
You will lose 10-30 last secs.
XL-Studios said:
More info here:
viewtopic.php?f=27&t=17172
and here:
viewtopic.php?f=27&t=13169
In short, you'll need a video tool and none worth a **** are free. This one works well on phantom files but the free version will only repair the first half of the video. http://grauonline.de/cms2/
When setting options for the repair, be sure to choose a reference file of the same resolution/fps as the damaged file. Also, select Enable AVC1 single mode. I've purchased the software so if you have a file or two that you need repaired, share them with me and I'll fix them for you.
Does your phantom and gimbal still power on? If so, just insert battery and power on and let the file finalise. If that doesn't work, try accessing it on the Vision app and playing it back for a few seconds.
Not sure what you are expecting to see on the video. Up until the power shut off, it was flying fine. As soon as the power is totally cut, I would assume that the camera would immediately lose all power and go black. It isn't like landing and just shutting down the motors prematurely without stopping the video first, with the battery still powered on. Seems you are describing an instant loss of all power which would instantly kill everything.
Yeah, i agree, yer not gonna see much. You had a battery/power failure. Nature of the hobby! Electronics 80' in the air. Gotta be prepared to say "s**t, that sucked" every time u fly.
Though may be a bit late for the topic starter, might be of use to someone with the similar issue.
Try out this online service: Restore.Media - they recover / fix corrupted files (yours seems exactly the case I guess - valid data, no service information in the headers).
