Just trying to get you pic a little better for viewing. You do need to check into why the resolution is set so low. I pulled this one up to the normal level. The pic is now brighter, but should look better when someone clicks on it to view the larger size. Btw,mthey have the thumbnail resolution set at 75% or less which why the images do not look that clear until you click on it and burn even more bandwidth.
