HELP flashing red/yellow/green not connecting/ new p3
Pleasae help
I'm new. so thanks man your savin me!
out of box today ....not connecting turn it on and get
flashing red yellow green fast in back and solid red in front.???
strange sound like beep beep beep beep
front solid red back 3 light
beep beep 5-10 min same?
normal
The red..green...yellow flashing is normal on start up. the AC is in diagnostic mode. It should only be that way for a short amount of time. Then the rear lights should flash yellow while the AC warms up. If your getting the 3 color flash for 10 minutes, something is likely not right.
Is your RC on? Did you remove the gimbal clamp (clear plastic piece on camera) and the white foam piece behind camera?
Not trying to be rude...but did you read the manual?
Reactions: CostaPete
upgrading firmware// on remote then asked to re calibrate ...so i followed instruction and am re calibrating. now
3 light just stopped
now green two flash!!
happy Everything! thanks for the replies! i believe I'm good to go
Yep...you're good to go.
Enjoy and take your time
thank you. I'm in costa rica , own a vacation rental..if anyones in costa rica and wants to connect. its a droners paradise
tpren3
