Is the signal score #'s accurate? am I to assume that if I do the exact same run, and one run has lower #'s and another run has higher #'s is this a way to test signal strengths ?
Using the same drone, same remote, testing different antenna's could you essentially determine which antenna is better?
thx
thx
