- Joined
- Jan 19, 2018
- Messages
- 28
- Reaction score
- 4
- Age
- 69
I have been reading the questions and replies to all the threads/discussions I can find relating to range extenders. I have a Phantom 4 standard and have actually flown it almost exactly 3 miles in line of sight without difficulty. This was a straight out and back flight with no obstructions in between. What I need to be able to do, however, is fly up to about a (1) mile in forested areas and then drop the aircraft down to about 25 feet or so and be able to see as clearly as possible the details in these clearings. I only fly about 150 ft in altitude just enough to be comfortably clear of the trees. My experience with this thus far has been to lose video transmission after only about a quarter (1/4) mile when dropping down below about 50 feet when fairly thick forest is between the controller and drone.
Itelite, Drone World, Titan Drones and others all sell extended range antennas that claim to accomplish this type of task. I am looking at one on the Drone World website store that says for Phantom 4 Standard only. It seems that some antennas work with the Phantom 4 Standard and the Phantom 3 Standard but not others in the Phantom 4 family. Is this because of the camera, the drone or both. I am under the impression that the difference in the Phantom 4 series is the camera is a better/faster quality as you go up from the standard but the aircraft itself is the same basically. Is this the case???
The other question, which I mentioned briefly in another post a few months back, is concerning elevation of the antenna. When I was in the army in field communications we learned very quickly that even minor elevation, 15 to 20 feet, would make a significant improvement in quality signal transmission. Based on that I would think that putting an antenna on an elevated pole (found a 25 ft telescoping one on ebay) and running co-ax cables to the controller would greatly improve the signal transmission. I would think with quality cables very low signal loss would occur compared with the signal gain from the elevation.
Someone please give me the low-down on these two issues. I know someone on the forum could answer this one in their sleep.
Thanks!!!
Thanks!!!
