Head Tracking - Set-Up with H3-3d Gimbal - Tilt function lim
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by AnthonyV, Jun 21, 2014.
  1. AnthonyV
    Hey guys my current set-up is as follows:
    DJI 550 with Naza M V1 but upgraded to V2 firmware
    DJI H3-3D with external GCU and PMU
    DX8 with FatShark Attitude goggles
    I have the DJI h3-3d working properly and also have the head-tracking set-up and working with my dx8. However, I can only get the head tracking to work with TILT which is ran to X1 on the Naza M controller (going to AUX3 on ar8000 - knob on radio).
    I have tried both F1 (Roll) and F2 (pitch) going from NAZA-M to AUX1 on the ar8000 in order to move the camera LEFT/RIGHT with head-tracking but it will not work. I have set-up the Trainer so that both AUX3 and AUX1 are slaves. Aux3 TILT is working perfect.
    When I connect to the H3-3d DJI Gimbal Assistant 1.1 it will only show me Tilt. Is the h3-3d limited to only head-tracking with tilt? Or am I doing something incorrectly?
  2. OI Photography
    Clarksville, TN
    Re: Head Tracking - Set-Up with H3-3d Gimbal - Tilt function
    As far as I know it's not possible to directly control the yaw axis on the H3-3D. I admit I've never tried to set up head-tracking with it, but I don't know of any other setup that will let you control the gimbal on that axis.
  3. The Editor
    The H3-3D is permanently fixed in follow mode with a deadband around centre of approx +/- 5 degrees on the yaw axis.
    This can not be altered or controlled. What you want to do can not be achieved with a H3-3D.
    You could try one of these based on the Alexmos GCU with 3rd axis extension. That will do what you are after (assuming you wire it correctly).
    See here -> http://www.hobby-wing.com/arris-cm3000-gopro-hero3-brushless-motor-gimbal.html
  4. OI Photography
    Clarksville, TN
    +1
    If you need a 3-axis gimbal and the H3-3D doesn't fit the bill for you, I'd say the next best option is the CM3000...I was very pleased with their 2-axis version I own (CM2000) and came very close to getting the 3000 as well. I settled on getting the H3-3D just for its lighter weight and simplicity of connections, but the CM3000 is a great gimbal and it's been around long enough that it's in (I think) the 3rd-generation of revisions by now.
  5. The Editor
    Yup - I have one sitting here on my desk next to me!
    Excellent gimbal and VERY configurable. Way more so than the H3-3D.
    They actually have the 'Pro' version available now (based on the same Alexmos architecture) which allows full 360 degree yaw with AV feed through slip rings.
Similar Threads - Head Tracking Set Forum Date
Headtracking set up? FPV (First Person View) Mar 23, 2015
FPV Head Tracking Setup Question Phantom 2 Discussion Jan 8, 2015
P4 Firmware Firm update Phantom4/DJI Goggles/headtracking Firmware Jul 8, 2017
Vr goggles and head tracking General Discussion Jul 6, 2017
Vr goggles head tracking General Discussion Jul 4, 2017
