P3 Firmware Have a problem on my P3 Pro keep getting--P3X_FW_RESULT_AB
Prescott,Az
I have a Phabtom 3 Pro and every time I fly .I have this happening on my bird --P3X_FW_RESULT_AB Also here is the txt file Attached-
The Phantom flies OK but I keep finding this crazy TXT file on the little SHDC card, but it seems to fly ok! Any help and suggestions would be Most Appreciated !
Thank You!
Format the sd card as you no longer need it. Now you can take pictures or movies which will go onto the card. You can either format the card in a computer or use the Go App to format it in the bird.
Reactions: Kevin G
The last line in the text file states that the upgrade that is being attempted is the same as what is already in the bird. No further action is required. Go ahead and delete the installer.
Reactions: Kevin G
Its because you have the FW bin file on the card .. personally I like to have the bin file there - then any new battery etc. is updated on use without need to download.
The txt file and the associated bin files are so small as to be no issue at all ... ignore and go fly.
Reactions: Kevin G
Nip
