Green LED wont blink during Callibration
when i try to GPS calibrate my drone phantom 1 by rotation it physically, i get the green light at first but when i try to do the second part where you spin it with LED pointing up, the LED wont blink green. please help
The procedure is
Start the calibration
Hold the quad at arms length away from you making sure you have nothing metallic on you or around you
Rotate 360 and then a bit more ( never seen. Quads finish the first stage at 360
Now tip the quad face down and repeat the above steps
The procedure is
I did this any i think it worked, it did change the LED as i made my 360 degree, however, it rapidly blinked yellow, then waited a second, and repeated. i don't know if this worked or if something is wrong.
Yellow flashing fast is a non bound transmitter, slow flashing is acquiring satellites i think
Scav8tor
