Got me thinking about that so I took a look. Sure enough, the top holds it in place. Must be the reason DJI did not put black goo on it.N017RW said:You're right. There is no real sense of it fastening into place.
Does it look like it has been rubbing or chaffing against the top shell and shielding material?
Mine is held in place once the top shell is attached and I can see where it has rubbed against the shielding material.
It [mine] can't actually come out when assembled but having said that many have used varios means to create a better locing 'feel' by bending pins, adding glue, wire ties, shims, etc.
