got a new rc and cannot connect to aircraft!
Not that I am aware of... you should be seeing the " CAMERA" button in blue after selecting: Equipment/(your model)
Turn off everything... then turn on drone, wait 30 seconds.. then turn on tablet/phone... open DJI go/ select equipment (your model... look for BLUE Enter camera button
I can enter the app but thats all.without any connection between rc and smartphone app I think that I can't do anything ;(
I hope that the mavic will come in the next 2 weeks :D
is it possible to connect the smartphone directly to the p3 without remote?!
Not that I am aware of.. read my last post first...
Also, if you have another tablet/phone/device , try installing DJI on it to see if it works at that point.
I try it out on 2 iPhones and iPads
when there is no solution to enter with the app directly to the drone then I can't do anything...
wo ssid of the rc so no way to work with them.
According to it you DO have a small hole next to LED light on side of drone that you need to poke a small pin into to start linking process.
DJI go should have a CAMERA button visible
I think you are not looking in correct place of app... (Trying to help here)
thanks I know that..
I think my rc is broken.
i tested it right know.
with a rc of a friend works directly and my rc doesn't work with his drone^^
i was sure that the rc is broken cause it doesn't start!
nothing ! when I switch it on, nothing happens!! only flashing green light makes no wifi !
and makes no sound^^dead ^^
Try removing/replacing SD card..
Page 24 : linking
only flashing green light !
the battery status less are off! but its fully loaded ^^
what you sent me is useless when the rc doesn't go on?!
Ok... I did not help at all, researching a drone that I don't even own... I fly a advanced version... I spent my time in vain... Have a nice day.
So, post # 32 says in part that a friends RC works when linked to his A/C ---- but the OP's RC does not.
I'd have to ask two questions here: Are you SURE your RC is fully charged ? ...and if it is, have you tried to link the RC and AC using the GoApp instead of the RC toggle method?
Just shooting in the dark here.......
src72
