GOPRO HERO 4 BLACK FREEZES
I recently bought a new Gopro hero 4 from Amazon, and I mounted in a h3-3d zenmuse gimbal on a phantom 2. At the very beginning everything worked fine. Recently when I turn it on and either press the mode button few times or press the rec/config button once, it freezes out and I have to reset it by pressing and holding the mode button.
I went into gopro support page and they recommend to upgrade the camera firmware, there is a newer version that the one that is installed in my camera, the problem is that after I copy and unzip the update file and insert the sd into my camera and turn it on, appears a BUSY message and hangs there forever.
Does anyone knows how to solve this problem or I will have to claim a warranty?
thanks
thanks
No idea, but make sure you try it without the SD card in, or at least try another.
Also - curious why you are not updating the firmware using app over wifi. All that file copying via SD card should be unecessary.
