That's good info sir. I hope you'll consider posting that info in the P3S forum as well. I expect it would be helpful to other P3S owners. Cheers!So I picked up a Phantom 3 Standard Thanksgiving Day at Wal-Mart for $369, my sister actually bought it and also got a 3 year warranty which was probably a great idea... anyway.
I have the Google Pixel XL and used the phone and also the Daydream headset this morning without much of a problem. In regards to Win Martinez's problem of Daydream app automatically opening when inserting the phone into the headset, I also had this problem. The way you fix it is by disabling NFC on your phone.
Later tonight I attempted to fly the P3S and had some issues... I couldn't connect DJI Go or Litchi to my P3S... I thought perhaps an update to the latest firmware (1.7.90) will fix the issue... Nope! I messed around with my phone some more and found that when I connected to the remote's SSID there's a message of no internet connection (this was expected) BUT when I opened a browser window I got another alert telling me no internet connection, do you want to stay connected to this SSID? I said yes, went back into DJI Go and still no go, I'm stating this because perhaps the phone was blocking the network connection which may lead to a problem for some.
Eventually I figured out what my problem was. I had to disable my cellular data 4G connection on the Pixel XL and everything started working as expected. I opened the DJI Go app and it immediately connected and I could see the camera view.
So to answer your question, Yes Google Pixel XL is compatible and also the VR Daydream headset with Litchi but you'll have to (easily) tweak a few settings to get it working! Hope this helps!
Yep that worked. Turned off my cellular connection and everything works great. Seems like an odd problem. Hopefully a fix will come.
Yup. But if you dont turn Mobile Broadband off, it wont connect to Litchi at all Thats the only downside.I don't have Litchi yet (found this thread while trying to look up using my Daydream with the Phantom), but I do have a Google Pixel XL. Google has added a "feature" which will automatically turn off wi-fi if you do not have an internet connection. To turn this feature off, go into your Wi-Fi settings, click the gear in the upper right corner, and turn off "Switch to cellular data automatically". That should hopefully fix this issue without having to turn off 4g every time.
As I said however, I don't have Litchi yet and weather isn't conducive to testing here until spring so I'll wait until then to pick it up, but if someone can test this in the meantime, let us know how it turns out.
You know what, I was an idiot that didnt read your post properly and assumed it was the same as what others have said... You know what they say about assuming.Is that even with auto-switching turned off? It sounded like it was an issue of trying to connect to the internet and was disabling the wifi. Interesting.... are there alternatives to Litchi? Also, what is the performance on the Pixel XL?
report back
Good to hear that it led to a (better?) solution. I have the US version without developer mode on (although i usually do turn it on) and i see the options from your first picture.
