how many times must i repeat? it flew away into power lines.It hit power lines. There's the cause of the issue. Not a fly away
Battery level of the controller?
Seems like if it lost connection (after hitting an assumed powered wire , grounding issues aside)
Or interference with proximity of power line may have initated at RTH?
You will get 30% off a new phantom if you send it in along with your valuable controller.
Fight and ***** long enough and they may offer 50%
Driving up the cost for everyone else.
Just to be clear, you were on the ground and switched to F mode with the motors idling, right? And then without any stick input, you're saying the craft took off by itself while in F mode?i was in "p" mode then landed and then switched to "f" mode then the copter started raise right into a power line it then flipped upside down full throttle into the ground, after i could not shut down the motors via the rc i had to grab it and pull the battery to kill it while doing so it had so much thrust as if it was on steroids it almost flew out of my hand that's how my arm got chewed up... what do you want from me? read the post.
first part is correct then i throttled up then it took off right after i initiated "follow me" i guess I should have been more clear on that but today being so hectic after my $800 drone crashed and everyone nitpicking at my post I'm just frustrated is all.Just to be clear, you were on the ground and switched to F mode with the motors idling, right? And then without any stick input, you're saying the craft took off by itself while in F mode? So I assume this happened so quick you didn't have a chance to switch the RC to P mode or A mode, right?
It appears you initiated "follow me" without being in the air, which I think is pilot error. From my recollection you must be in the air before switching to F mode, then you can enable follow me, waypoints or POI commands. You should research that to get clarity about using Follow Me mode. I think you're going to find pilot error being the cause.first part is correct then i throttled up then it took off right after i initiated "follow me" i guess I should have been more clear on that but today being so hectic after my $800 drone crashed and everyone nitpicking at my post I'm just frustrated is all.
go kick rocks you weren't there you didn't see the scenario take place.Power lines seem to be your issue never ever put your phantom into follow me unless it's at the right elevation ie above power lines, sorry but your title "follow me is garbage" is actually my "pilot flying is garbage" CSC would have saved your arm.
From what we know about P3P issues good chance we have operator error however the .dat file may just make a donkey out of that theory.Well NASA technology should never fail right? Are you sending your telemetry data in for us to see?
Having your arms chopped up by a quad is by definition 'operator error'.From what we know about P3P issues good chance we have operator error however the .dat file may just make a donkey out of that theory.
