Gimbal overload
Fallston MD USA
Getting this warning on the app and the gimbal is going crazy. It won't stay still. I has taken a hard hit in a crash. Any ideas how to correct it without spending $500?
Is it something you did that gave you the warning? Or it just happenned all of a sudden?
What was damaged in the crash? Is aome component obviously bent and likely to cause binding. Any of the electrical connections likely to have been disturbed?
Sorry, did not catch that part.
Any physical damage? If yeah, you might need it repair.
No obvious signs of damage. It does it constantly. Yes, I did try the recalibration, but it didn't help. If you're looking at it from the front, it always dips away from the motor. It does this every few seconds, regardless of flying or not.
take a look at this and see my post about this problem. I posted a fix to this problem a 2 days ago. it is a problem with the motor post alignment in the rear gimbal motor which can be fixed with a simple set of pliers or if you are not so lucky a gimbal motor circuit board replacement.
spaz_12
