Understood, but THAT much heat after just a few minutes is a bit odd.It's going to get fairly warm. Many parts of the phantom will warm up quite significantly. The motors, the battery, the gimbal. Just to name a few. It's normal. You can't forget that this is basically a flying computer. All that processing (video processing in the case of the gimbal) generates heat.
It's meant to be flown and thus cooled by the air temp and props spinning.Understood, but THAT much heat after just a few minutes is a bit odd.
So one good piece of advice is do not let your P3 stand still (and on) for too long.It's meant to be flown and thus cooled by the air temp and props spinning.
Curious to know if it gets hot when using the simulator. I never bothered to checkSo one good piece of advice is do not let your P3 stand still (and on) for too long.![]()
a fan is a great idea--- !The unit does warm up pretty good on the bench and it is normal.. IMHO, I would leave it powered up for more than 20-30mins on the bench. Maybe even run a fan to keep it cool if using the simulator
