Gimbal works fine, just no image transmission. every time I turn it on, The status light turns red, and then turns off. I tried a new SD card but that did not do anything to help the issueAre you saying your gimbal works fine?
But camera does not work??
Your title confused me.
So, no Hard cranes? But crashes????
Try a different SD card.
Thought I would jump in and try not to confuse the issue with another issue, but a conversation might help.
rifr4a4, you might have a bad main circuit board, (mother board). However, there is really no way to determine that unless you put a fully functioning camera on your drone and see if it is, in fact the camera. Not sure how old your camera is. If it came new with your drone, or was a replacement camera. Has it had any repairs made to it? With a bad main board, you can still have a good gimbal.
Armyvet's issue is most likely a ribbon cable issue. Check for very tiny tears or abrasions in the cable, especially where the cable enters the roll or pitch circuit board covers.. Check for limited clearance where camera swings near cable. And check for a loose cable in places where the adhesive may have released itself. And finally, make sure the camera module swings without binding in the portion of the cable that is protected by the "U" shaped bracket next to the camera housing.
Once again, if you purchase a new ribbon cable, don't be lured by a cheap price. I have renewed a camera back to full function just by replacing the cheap counterfeit cable. Double-ply, like the original DJI cables is the only way to go.
So, here is another similar issue with a different twist. Since I repair P3P, A and Std. cameras, I have to have all three model drones to test the cameras. My P3P drone started to have a puzzling image issue a couple of weeks ago. With a good color image on the tablet, I would touch the drone and the image would freeze and go to black and white. I would wait 15 to 30 seconds and the color would reappear with full motion in the image. This week there is now no image, but the camera works fine in the P3A. I have been told that image signals originate in the camera's main board, but this issue doesn't seem to support that. I thought it might be the TX, but after swapping TX's this morning, that theory is incorrect. SO, it must be the module underneath the Positioning circuit board, where all the antenna wires connect. I would name this the wifi module, until someone can educate me to the contrary.
Does anybody have any experience with this issue?
Thanks to any and all in advance!!
JIm
P3S here.Bill, I've never seen that error before. What model do you have?
BTW, if you are not familiar with swapping out a ribbon cable, watch a uTube video first.
Jim
If I had your camera on my bench and had the issue you describe, I would disassemble the gimbal, right down to he motors and do a close inspection. I use a 5X eye loupe and inspect the 3 tiny chip sensors on all the motors. Look for gouges in them or a complete dislocation of the sensor at the solder points. I would also remove the motor housing and inspect the black ring, (magnetic race), for chips or gouges and also look for any broken wires in the motor windings. The quickest way to spot a broken wire is to press silly putty, yes, silly putty onto the top of the motor. When you peel the putty off any broken wire will show up. I also use the putty to clean out the race area before I reassemble. This method removes any metal shavings or dirt. I have had cameras that crashed into the dirt and rendered the pitch and roll motors useless until I cleaned them out.
Also inspect the short ribbon cable on each motor. If they were removed without flipping the black lever up, they will get deep gouges in the gold contacts and won't make good enough contact to function. By the same token, if the ribbons were removed several times, the small divits in the gold contacts get deeper and finally will not make a good connection.
Let me know what you find,
Jim
Thanks,Hi Bill,
I'm happy to work on your camera. I've worked on so many of these cameras I can almost replace a ribbon cable in the dark. I charge $25 to replace a ribbon cable, but, yeah, there's always a but. Are you sure that is all that's needed? I charge $15 for an inspection/evaluation, which is part of my process of tearing the gimbal apart. I always test the function of the unit in my test drone before I disassemble it. My next step is to remove the gimbal from the main circuit board and test them separately and then I go to work. I would contact you first before I make repairs. You can contact me a [email protected] for shipping info.
Jim
