Gimbal Disconnected/ No Video Transmission
Hi all. Odd issue with my P3P.
Firmware is the latest on copter and Rx
Copter flew perfectly for 3 batts a few weekends ago, and the only thing that has changed between then and now is an updated version of the DJi Go app on my iPad Mini 4.
Symtoms of the issue are:
Turn the equipment on and everything seems to work fine apart from the camera not displaying on the iPad (Gimbal reports that it's "Disconnected" in the main menu)
I can still move the camera with the control wheel on the radio.
If i leave the copter and ratio turned on for approx 10 to 15 minutes i then hear the 3 beeps to signal that the gimbal camera have come to life and i then get a perfect video display on mt tablet.
I've had the gimbal off to check the connections. The 2 main cables looks fine. The ribbon cables do seem to have some seperation in them, but i think they've been like this for quite a while.
Any ideas guys?
I just had the same problem - I switched the SD card and that fixed the problem. Doesn't seem like an SD card would have anything to do with the gimbal, but it did on my P3P and I see the Mavics had the same solution.
