My radio is a polygamist...
...but that is for later. Right now, I am dealing with a 2 steps forward and 3 steps back scenario.
I set up the quad to test out the programming- took her out todat to run through the paces... and it was a beautiful thing. Single brand new, freshly charged Maddog 2700 (inside the battery bay) and the gimbal in perfect shape bar the torn grommet, and the new 10CAG set up with failsafe switch (no need to shut off radio) and full capability to switch from manual to ATTI to GPS, nd HL and CL all functional. Tilt operational, and a solid compass calibration had her rock steaady in the first no wind day since last fall. I had added a couple of cool custom turned wide, shorty thumb pads to my sticks (I am a thumb flyer- no pinch) and the control was stellar... too stellar... I got some wild hairs up my *** and lost track of time on the 2nd battery and smacked the Phantom... really hard. Too hard.
I didn't notice at the time- everything seemed ok other than a few cracks and scrapes- but when I got her home, pulled out another battery and got ready to fire her up to see if she was alright... I discovered a catastrophic failure: 1 of the motor shafts is ever so slightly bent. I originally thought the body had tweaked- it happened on my first wreck, and after repositioning the body shell and reseating things, it was fine- but I manually rotated the props as I always do to check distance against the canopy and the right rear prop skimmed the top on one side... whereas the others are about a 1/4 inch above it. I was shattered.
Then I checked the mail... and my small retracts showed! YEAH! I got them home- had the Phantom pulled apart anyway, and took my y cable and plugged it into channel 8 on my new FrKy Rx... and one of those is bad. *sigh*
The only good news is he other one worked, it is super lightweight, and I will have retractable landing gear on the new shell once it arrives- of course I have to swap out everything but that is pretty easy.
I looked at Dewey's P1 to P2 shell mod and for a minute considered it... but I have a nice case that fits my current rig well, and I do not want to do all that work- and I like the body of the P1 to be honest... the newer version is too bulky for my taste.
I had 11:14 on the maddogs average- with a total up air weight of 1250grams... and that is the best time yet on any battery config. The new shell will be lighter- the landing gear will not add but instead remove weight, the retracts are lighter than the heavy dual skid aftermarket I had (retracts are much heavier than stock landing gear) I need this as the gimbal I want will add to my old one's weight- and with the single battery, I am thinking I should be in the 9 minute range at worst... and I am so cool with that.
Now- I need a custom mount for the retracts (thinking a saddle bend under the bottom like a gimbal mount, under the gimbal mount- with tabs or wings out the sides to bolt the retracts to for my struts. I confirmed the programming in the radio... so stock Arris 3000 settings, with a tilt, retracts, and if I can figure it out, a switch for head tracking activation... I will just set the speed on tilt and yaw at fixed unless I can get that on my variable knobs... I should go ahead and put T Motors on as well I suppose. ****... smacked up and cracked up just in time for spring. I gotta hustle some cash flow... so how many of you'uns can I put down for tee shirt orders? None? ****.
That only leaves one question... what kind of paint scheme on the new shell?
...and that polygamy crack? My 10CAG has an affair with an RCLogger Eye One Xtreme now... and that little quad is about to undergo a massive mod- killer foldable custom CF fpv frame so the gopro mounts up front and battery out back for CoG control...
