Free online DJI flight log viewer
Thanks, msinger
I keep getting "The connection to the website was reset. Error Code: INET_E_DOWNLOAD_FAILURE" error. I switched to Google Chrome instead of IE and I t works. Thanks again.
Which version of IE were you using?
I tried Microsoft Edge 41.16299.248.0 and all worked as expected. I'm not sure why it's not working for you.
I released an update today that adds the capability to process encrypted TXT flight logs created by DJI Fly 1.2.2 (or newer) or 3rd party applications using DJI SDK 2.4.13 (or newer).
BTW, if you're processing a large amount of flight logs, doing commercial drone work, and/or want to keep your flight logs private, Flight Reader might be a better option for you.
Reactions: Oso
Glad the old on-line version is still available Mike, this 82yo UK pensioner can't afford to buy anything at the moment, and I only fly a P3A anyway so no encryption ??
Reactions: msinger
I released a new version today with the following changes:
  • Extracted available flight messages and warnings.
  • Resolved issue that was causing the first couple of rows in the map view to have misaligned columns for some drone models.
  • Resolved issue that was causing negative height/pitch/roll/yaw values to be displayed as positive values.
Reactions: Oso
  • Added "Home.dataRecorderFileIndex" field to the log. This field shows the index used in the filename of the DAT flight log (e.g. FLY72.DAT) created on the drone.
  • Added "Data Recorder File Index is X" message to the map view and aircraft log "APP.message" column.
Reactions: Oso
  • ADDED: Added the following new fields:
    • CAMERA.sdCardIsInserted (True/False)
    • CAMERA.sdCardState (Normal, Card Too Slow, Write Protected, etc.)
    • HOME_HeightLimitF (Max altitude setting in feet)
    • HOME_HeightLimitM (Max altitude setting in meters)
    • HOME_IsMultipleFlightModeEnabled (True/False)
    • HOME_Wind (Calm, Moderate, or Strong)
    • GIMBAL.mode (Free, FPV, or Follow Yaw)
    • RC.playbackDepressed (True/False)
    • RC.downlinkSignal (0 to 100%)
    • RC.custom1Depressed (True/False)
    • RC.custom2Depressed (True/False)
    • RC.custom3Depressed (True/False)
    • RC.custom4Depressed (True/False)
    • RC.uplinkSignal (0 to 100%)
    • RC.wheelDepressed (True/False)
    • RC.wheelOffset
  • CHANGED: Renamed the follow fields to make them more descriptive:
    • RC.goHome → RC.goHomeDepressed
    • RC.record → RC.recordDepressed
    • RC.shutter → RC.shutterDepressed
  • CHANGED: Updated the "BATTERY.goHomeStatus" field to show the correct values (Counting down, Idle, Executed, Cancelled, or Other).
  • FIXED: The logs for some drone models were always showing false in the "CAMERA.isPhoto" and "CAMERA.isVideo" fields even when photos were taken and/or video was recorded.
Reactions: Meta4 and Oso
  • ADDED: Added "Battery.current [A]" field to show the real time current draw of the battery.
  • FIXED: The "Battery.status" field was displaying "User Battery Req Land" in cases where it should have been displaying "User Battery Req Go Home".
Reactions: Oso and cheddarman
  • ADDED: Added support for the Mavic 3 drone.
  • ADDED: Added support for the Matrice 200 V2 and Mavic 2 Enterprise Advanced drones.
  • FIXED: Resolved several decryption issues causing some GPS coordinate and speed values to display incorrect data in Mavic 3 flight logs.
  • FIXED: Resolved several issues preventing some Inspire 1 flight logs from being processed.
  • ADDED: Added missing model names for the Matrice 210 RTK V2 and MG-1P drones.
  • CHANGED: Updated times to display two hundredths of a second.
  • ADDED: Added incomplete records that sometimes appear at the end of DJI TXT flight logs. While these records are often missing key data, the data they expose could be useful for troubleshooting purposes.
  • FIXED: The battery data could not be decrypted in some flight logs. That failure was causing Flight Reader to generate empty log and KML files.
  • FIXED: Resolved an issue that sometimes caused the max speed to display as infinite.
  • ADDED: Added support for the Matrice 210 RTK & Phantom 4 Multispectral drones.
  • FIXED: Handled several edge cases that were causing logs to fail to process when bad data was discovered.
  • ADDED: Added "RC.downlinkSignal" and "RC.uplinkSignal" for Litchi flight logs.
  • FIXED: Correctly converted the "BATTERY.current [A]" value for Litchi flight logs.
Reactions: snowghost
  • ADDED: Added support for processing Mini 3 Pro flight logs.
  • ADDED: Added ability to process Drone Harmony CSV flight logs.
  • FIXED: Get all 16 characters for serial numbers in the RECOVER section.
DonT
