Free online DJI flight log viewer
I released a new version of my log viewer today with the following changes:
  • Made improvements to resolve incorrect data that was sometimes being populated in the "CAMERA.isPhoto" and "CAMERA.isVideo" fields.
  • Added the following new log fields:
    • WEATHER.isFacingWind: When true, the front of the aircraft is currently facing a headwind.
    • WEATHER.isFlyingIntoWind: When true, the aircraft is currently flying into a headwind.
    • WEATHER.windDirection: The cardinal direction the wind is blowing from at the aircraft’s current location.
    • WEATHER.windRelativeDirection: The cardinal direction the wind is blowing from relative to the direction the aircraft is currently facing. For example, an East wind would be blowing toward the right side of the aircraft.
    • WEATHER.windSpeed [MPH]: The wind speed (in MPH) at the aircraft’s current location.
    • WEATHER.maxWindSpeed [MPH]: Maximum wind speed (in MPH) at the aircraft’s current location (so far in the flight log).
    • WEATHER.windStrength: Calm, Moderate, or Strong to indicate the wind strength at the aircraft’s current location.
  • Renamed the HOME.wind field to WEATHER.windStrength
Note: These fields might not be populated if you’re flying a DJI drone model released more than a few years ago.
  • Added support for processing Avata 2 flight logs.
  • Added support for processing Mini 4K flight logs.
  • Added support for processing Neo flight logs.
  • Removed the repeated “Auto returning to home” placemarks from KML while the aircraft is returning home.
  • Tips and warning messages that repeat in consecutive rows are now displayed once and not shown again until logged again later in the flight.
  • Some flight logs were populating the aircraft component serial number fields with unreadable characters.
  • Some battery fields were populated with a “0” when no data was available in the flight log.
Reactions: RodPad
  • Added support for processing Air 3S flight logs.
  • Added support for processing Specta Mini flight logs.
  • Added support for processing Matrice 4E & Matrice 4T flight logs.
  • For drones with dual batteries, the serial numbers for both batteries are now stored in the SERIAL.battery and SERIAL.battery2 fields.
  • Serial numbers can be found in the RECOVER.*, DETAILS.*, and SERIAL.* fields depending on where they are extracted from flight logs. All serial numbers have been combined together and stored in the SERIAL.* fields. When referencing serial numbers, use the SERIAL.* fields as they now provide the most complete data.
  • Resolved an issue that prevented photo and video data from being extracted from Mini 2 flight logs.
  • Added support for processing Mavic 4 Pro flight logs.
