- Joined
- Jun 28, 2014
- Messages
- 102
- Reaction score
- 0
Amit - Same results for me - please see - random voltage drops:
http://www.flytrex.com/mission/quadcopt ... -AmLshGzg/
bbfpv said:Same deal here. Very choppy voltage readings. Anyone heard back from Amit on this? Do we know that its definitely just a display issue?
bbfpv said:Spoke to Amit, he said stay tuned this week, s/b fixed. But it is in fact a cosmetic issue only, your bird's voltage isn't actually spiking.
bergenfelter said:Mine seems to be getting worse as time goes on. This one is really bad - actually obscures parts of the rest of the data. I did receive an answer from Flytrex last week - "they are working on it"
http://www.flytrex.com/mission/quadcopt ... -f3gZ1Z4t/
milspecjsc said:bergenfelter said:Mine seems to be getting worse as time goes on. This one is really bad - actually obscures parts of the rest of the data. I did receive an answer from Flytrex last week - "they are working on it"
Let me chime it to say I too am having the same issue. And, just as Bergenfelter reports, the issue has been getting worse each flight I log. My bird flies perfectly and there is no interruption in video recording but it is unnerving to see the reported spikes. I have opened a call and have provided graphs ever couple of days just to ensure the case stays open. To date, the only reply I received was that it is a known issue with the parsing of the data but no update as to when it will be resolved.
amitregev said:Hi guys!
Thank you all for the reports and details! I'm sorry for the slight delay getting this fixed.
We just finished applying a fix for the voltage parsing code and the voltage drops that were showing in the flight graph are now fixed. The fix was also applied to all previously uploaded missions, so if you try to review your existing missions that had this issue the voltage should look much better now and report actual voltage (usually you can expect to see a slow and gradual decline during the flight).
As an example, here is one of the reported missions that had the same voltage spikes in the graph, now showing the correct parsed voltage data:
http://www.flytrex.com/mission/quadcopt ... -LJJOVRlt/
Let me know how things look for you with the new fix applied.
Thank you all for the great help!
Hughie said:Can you confirm that no firmware update is necessary, and the update was only necessary at your end ?
bbfpv said:Confirmed the voltage spikes are no longer being displayed. Thanks Amit!
