1. Disable VPS - it gets disoriented over water
2. Check the winds direction. If going with the wind, coming back will take a significant longer time, so make sure you have enough charge with your battery.
3. Check the wind, yes again- if it is too strong - you may not be able to get it back.
4. Know how to fly in Atti mode - sometimes you will need the extra speed it provides
5. Be careful of seagulls. they are known to dive onto phantoms
The P3 will not go any faster in atti mode - that was a P2 feature.Foosy, you are right on point with each of your comments, especially 1, 2/3, and 4!
YOU DIDThis applies to big water and distance, where you cant get it back,,,,,,
Be prepared to lose it, much bigger chance of not getting it back
Get one of those neck straps, so when your hands start shaking uncontrollably ,you can SHAKE IT OFF,,,Yes really
I'v never taken the VPS off( not saying its right or wrong,just,, I have never done it).
Depending on where your flying,,,Reset you return to home altitude. When I fly over water(the beach) I set it for 40'. The reason is ,,,if theres a problem and RTH is activated ,I dont need it or want it climbing to 100' first ,then descending from 100'.You can save a minute or 2(Just my opinion )
If your going for distance,,,,Play the wind,it makes a BIG difference on distance traveled.
Did I say ,,,,Be prepared to lose it?![]()
I couldn't help but be the one to give you your 1000th like when I saw 999The P3 will not go any faster in atti mode - that was a P2 feature.
Purchase a getterback just in case....
I've heard those don't work so well, nor would it support the weight of a sinking Phantom. I'm looking for a solutions as well as I'll be taking mine out in open water
Actually, it does, but not very much.The P3 will not go any faster in atti mode - that was a P2 feature.
