Flying my Phantom 2 Vision at -5 Degrees Below Zero
Minneapolis, Minnesota
I flew my Phantom 2 Vision at -5 degrees yesterday. It worked perfectly. My Samsung Galaxy 3 however, lasted just a few minutes before it froze up. My P2V was also very stable in a 10 MPH wind. Held its position very well as you can see. :D
This was taken December 7th, 2013 at sunset in Minnesota area code 952 with a 10 mph west wind.
Burrrrr...
I won't get that chance here in Louisiana.
Qwadjok said:
I flew my Phantom 2 Vision at -5 degrees yesterday. It worked perfectly. My Samsung Galaxy 3 however, lasted just a few minutes before it froze up. My P2V was also very stable in a 10 MPH wind. Held its position very well. :D
Are there any temperatures one should not risk flying the craft at?
Obviously one has to question the mental stability of someone wanting to venture out to fly when it's -30 C out, but -5 F (around -20 C) is getting close.
I ask because it's bloody cold here in Alberta right now and I'm definitely a bit of a loon who would go out! :p
DJI's own specs say the operating window is between +50C and -10C. Anything outside that an you're on your own if it goes pop! I would avoid such low temps if there is a lot of moisture about, though. However the lipo gives out a fair amount of heat whilst its in flight, so that will help to keep the internals warmer than ambient. In fact a freshly depleted lipo makes an excellent hand warmer after a cold flight!!
