- Joined
- Dec 14, 2018
- Messages
- 20
- Reaction score
- 12
- Age
- 68
Hi we are making a 5km water tunel in the mountain and I am supposed to film inside before we take water into the tunel. There are no gps signal. how shall i adjust my ph 4 to fly safe
Whether you "adjust" it or not, your Phantom will be in atti mode and flight will be tricky as the drone will have no brakes, so crashing will be easy.Hi we are making a 5km water tunnel in the mountain and I am supposed to film inside before we take water into the tunel. There are no gps signal. how shall i adjust my ph 4 to fly safe
My thoughts exactly. If you need to smooth the video out, put it on a gimbal and mount it on some small vehicle, like a golf cart. And some decently lights on the vehicle wouldn't hurt, either.Why use a drone? Regular camera should work fine, shouldn't it?
I'm not an expert on drones, but I am a professional photographer. GoPro would not be a good choice. The GoPro has a very small sensor, and because of that, they do not fare well in low light. You will get a very noisy image. A conventional camera with a full frame sensor would be a better choice, as they will handle the low light of a tunnel much better.I agree that any drone may not be the best choice. Distance, lighting, control over the craft, etc.
Assuming that the entire tunnel is driveable, a GoPro equipped small car or motorcycle may be a better choice. Both could easily be equipped with extra lights.
If safety is an issue, then a RC véhicule similarly equipped.
To get GPS reception, the drone has to have a clear, unobstructed view of a large piece of sky.Make sure your P4 is in Atti mode. You don’t want it to even try to get a GPS lock or you run the risk of it “correcting” its position when at the ends of the tunnel
Without GPS there can't be any RTH.Finally don’t forget to set your RTH settings. Don’t want any rapid unplanned disassemblies when your P4 tries to make its own skylight.
The vision system would require a well lit tunnel and a clear pattern or texture on the floor.Why wouldn't the Vision system work?
