Flight times on the P2 with all the gizmos attached?
Just wondered what sort of flight times you are getting when running all the gizmos such as the following....
gimbal h3-3d
go-pro 3+
OSD mini
Immersion 600Mw.
IB Crazy Ultra's antenna's
I seem to be getting around max 15 mins with 10% remaining showing on the OSD, but the P2 is flashing red. Is this typical ?
That is typical.
I get around the same times using the P2 in my signature.
I do have some LimeFuel 6000mAh batteries for it now, which should in theory give another 1.5 to 2.0 minutes, but I've not had a chance to test them as the bird died before I got to use one. I pick her up from the repairer tomorrow or Thursday and will finally test how much time I'm getting.
I land at 20%
I also have a flytrex 3G ,getterback and tracker. I see more like 12 mins tops, but I never let the battery get anywhere near 10%. I try and land by 25% because the battery decay is getting rapid at that point.
Similar setup with just a different tx and antenna, plus a Flytrex, and I average around 11-12 minutes with landing around 25%.
Seems your numbers are in line with the rest of us.
Don carlos
