First Timer Quick Questions
1: Antenna perpendicular to the ground or parallel with the range extender? The manual says perpendicular, but I've seen videos saying it should be parallel to the range extender.
2: Swapping Batteries. Mine came with 3, can I keep swapping them for continuous flying or will it over heat?
3: Recording FOV: 110 or 80?
4: Protection guards? Do you use any? Prop guards, gimbal guard....
5: Vision+ Utility Pro? Worth the price?
I keep mine parallel with the range extender. Whichever way you go, make sure the tip of the antenna never points directly toward your Phantom.
3 in a row should be just fine. Just don't recharge the batteries until they cool down.
I use these:
http://www.uavbits.net/store/p4/Carbon_ ... _P2V_.html
http://uavbits.weebly.com/inertia-guard.html
1. As much as you can, long side of the antenna directed toward the Phantom
2. The Phantom has 4 big fans that stop it overheating. DJI did a 72 hour test to show what a Phantom can handle.
3. Whatever works for you
4. Propguards can cause more (and potentially worse) problems than the prevent
