First night flight, first crash
I'm pretty new to larger drones. For the past year or so I've been practicing flying with smaller cheaper drones. I bought my Phantom 1.1.1 a few weeks back and had a good first flight, it flew perfectly, I got a good 13 or so minutes of flight before I brought it in.
After seeing a few threads here on night flying, I decided to give it a try. So tonight took it out, had about 7 or 8 minutes of flight, then it happened. As I was bringing it in, it lost power, and started an inverted fall from 75 or so feet. Motors powered back up, and slowed the descent, it fell through a tree and landed in the grass. No damage, not even to the props. Here's a short video clip from my camera which also survived, showing the crash.
It appears that this crash was indeed my fault. I had the motors set to immediately turn off, and I believe that in bringing it down I dropped the stick below 10%. I'm actually relieved that it was my fault, and not a problem with the Phantom.
Hmm... it's my impression that its pretty hard to accidentally shut down a Phantoms motors while in actual flight
You have to hold the throttle stick fully down for at least 3 seconds to shut the motors down.
Did you do that?
P.S. I doubt that you have a problem with the Phantom but it might be wise to go out (in day light ;)) and verify you can fly normally.
What are your battery low voltage limits? 13 minutes with a camera load on stock P1 is a long flight time IME. You should’ve had red LED low voltage warnings if not auto-land engaging.
I know you mentioned 7-8 minutes for the crash flight but how’s the battery balance?
I generally could fly mine safely for about 12 minutes with camera on board before the low battery warning light came on, using stock Phantom batteries and with some fairly aggressive flying.
I use 220g BLDC gimbal with 100g Hero2 (20-30g heavier than Hero3/4) using 45-90C nano-tech 2.2Ah batteries (slightly heavier 8ga wire) ‘always see 1st LV warning @ 10 minutes. This is very repeatable across several battery packs/bricks.
Did you do that?
It was set for immediate shut down of the motors, and I remember reading that holding the left stick at anything less than 10% throttle would shut down the motors. After watching the video I did notice that the motors cut out for a second, before I got back into the throttle. Which I think may have been what saved it from serious damage, as it slowed its fall.
Honestly, I'm unsure of the voltage limits. I may have been a little high on the estimate of the first flight. According to my video I had 12:39 of flight time, and I brought it in when I got the flashing red warning.
I'm pretty new at this, what do you mean by "battery balance"?
I’m terrible at explaining stuff like this but I’ll try.
The following graphs illustrate discharge of an 8S RC Lipo battery pack. Although larger (5Ah) cells and higher series count, they’re the same chemistry and voltage of our P1 2.2Ah RC Lipo.
A load s applied and drains the battery while we log/graph the voltage of each cell. These are new and good cells so everything’s fine until the very end. In this example load is removed and the voltage swing or floats back up a bit. Nothing is/was damaged or harmed because we were automatically monitoring to prevent OD (over discharge).
Notice how that lowest cell is the “weak link” in the series battery chain supplying power to our P1? The same amount of current (Amps) is flowing through that cell that’s flowing through the others. If anybody uses Ohm’s law, it’s pretty easy to see how bettery energy begins to be turned into heat.
In regard to battery balance we’re talking about the cells being in fairly close agreement in capacity to each other. Trouble is, unless we have something logging and/or monitoring the pack and this cells, we really don’t know what’s going on while the P1 is using the cells.
Some cells are defective and may sag much early than in this example. Or in the case of running a pack low one cell is simply used up before the others. The more you deeply discharge a pack the more out of balance they become so pack health and maintenance can be a very worthwhile effort.
That’s why many RC Chargers have testing functions and/or it may be worth fabricating a simple battery testing rig in order to be able to apply loads and measure individual cell performance to insure trouble free use and flight.
Good save.
Now go forth pilot and crash no more.
Another Neb question.....
In this instance, would he not have had this happen if he had had the Intelligent throttle option (instead of immediate) checked instead?
So, did you or did you not hold the left stick "fully" down for 3 seconds when your P1 seemed to lose power? .... (see my original reply).
Until that gets answered, I don't think it makes sense to think there is a problem with your Phantom.
P.S. For some reason the question of accidentally shutting down the Phantom in mid-air comes up continuously .... and it continuously gets wrong answers whether its possible or not. ;)
The manual is unfortunately poorly written and leaves a lot up to personal interpretation.
I believe that I did, since I was bringing it in for a landing. "I want it to come down, so the lower I hold the stick the further down it'll go" lol.
I don't think there is anything wrong with my P1 other than it being owned by an inexperienced pilot haha
You've got a good attitude.... you'll make a fine pilot.;)
P.S. After you land, take notice of how long it takes you to shut the motors down.
You'll quickly realize its not something that you can do by mistake very easily.
Holding the left stick fully down for 3 seconds takes a "very" conscious effort.
Enjoy your Phantom.... I still do, even after almost 3 years.:)
Well, I'll be honest with you, a part of my good attitude is because my phantom came out of the ordeal with nothing more than a couple of grass stains. But, I'm really enjoying it, and if the time comes that I have an real crash I'm sure I'll buy another.
Couldn't agree more about how rugged the Phantom is... it was one big selling points when I first got them.
The only damage I've ever encountered on a crash was a broken prop a couple of times.
Be sure to carefully look over the quad after a crash.... small cracks on the prop hub and near the motor mounts are easy to miss.
