I have some questions that I need answered before I take off on my first flight. My specs are in the signature. P2 non-vision.
Ok, I have studied the manuals, watched videos, updated firmware, configured everything I can find in assistant sw and played with a mini quad.
I'm almost ready. I think.
But I have some questions.
In the assistant software, see the attachment below, In "control mode switch", it shows failsafe between GPS and Atti and between Atti and failsafe. Deos this mean, for example, if I lose GPS lock, the phantom will go into failsafe? I really want to go to Atti, right?
Second part questions,
On the Phantom, the GoPro gets very hot when left on a little while, is this normal? I assume it's charging from the Phantom battery?
I'm assuming that I need to unplug that fragile ribbon cable on the GoPro, (mini usb),to transfer data to PC, (and to charge via USB) ?
The GoPro seems to turn on when I power on the Phantom. Do I manually push the record button to start recording the video? Or is there some way to use the WIFI remote key FOB??
The GoPro has a blue, "blink, blink, wait, blink, blink", on the WIFI indicator light. Does this mean the WIFI is on or off? I know that I want WIFI off while flying.
I probably have more questions coming
Thanks in advance!
Thanks in advance!
