My attempts to install the latest firmware has hit troubles.
I used the prompt from my original software assistant- and installed the new software 2.20.
Then using the upgrade tab in the new assistant, I installed the new firmware. It called for tx recalibation- done- and all seems good.
The motor test is all there and working etc. BUT-
The last tab, 'info' shows the correct software version- but no info on which firmware version. And every time I rerun the assistant it prompts to upgrade the firmware.
I knew I should have left well alone :roll:
