I just started using drones in the last 6 months, I have spent over $7000.00 gearing up to do real estate videos and aerial pictures. From what I have read of the proposed regulations, it will all but put me out of business. I live in the Upper Peninsula of Michigan and the internet and cell service is very limited. I don't see anyone hurrying around and putting up towers here, we can't even get funding to fix our roads.
I really have my doubts that the FAA will care one whit that you don’t have an internet connection. Worst case scenario from their perspective is just that they put you on the ground, which was the intent to begin with. People in big cities, such as those faceless bureaucrats in the FAA office, are going to operate based on what they know; either pervasive 5g service everywhere, or people who are spending massive amounts of money on aircraft anyway, and really don’t have a problem adding a bit to that sum if an internet connection is required.You're worried over something that is still very much in it's infancy. It's gong to take time to get the regs worked out and odds are it won't be finalized in it's current form. After that time the infrastructure will have to be built and installed.
It's not going to put you out of business it just seems like it right now. There will be provisions etc because MANY of us operate in limited to NO cell service areas. You're not alone and you're not going out of business right now because of these proposed regulations. With $7K invested in 6 months I surely hope you have a very profitable business going.
My estimate, going from your current investment/spending rate is that you'll be probably $42,000+ into the game by the time this goes 100% LIVE in 2-3 years from now!!
For those of you, like me, with an interest in drones for photography … take a look at what is coming.
https://s3.amazonaws.com/public-inspection.federalregister.gov/2019-28100.pdf
Unbelievable … 319 pages !!
If they’re going to require ADS-B out for drones, why not make it for any drones flying above 400 ft., or those applying for waivers to fly in controlled airspace …
Imagine what your TCAS will look like when all drones have ADS-B out ??
And what about the problem w. limited numbers of ADS-B towers and little low-altitude coverage .. thousands more towers??
After 12/31/19 you can ‘comment’ on the proposed rule here: Public Inspection: Remote Identification of Unmanned Aircraft Systems
I urge you to pass this around, and consider commenting …
How does it broadcast to aero scope? I have the same questions as @Porc. What will the receiving infrastructure consist of to receive from the aircraft?FAA does not want the UAS to use ADS-B because that’ll busy up the screens so to speak.
Even my P4P+ has the capability of broadcasting its ID to aero scope and DJI says they can probably send software update to other versions to do same. That is the way to go in my opinion on the preexisting drones.
I got to page 75 so far... and I see there will be a 3 year exemption for us that already have drones.
This won’t happen overnight.
Details, details...How does it broadcast to aero scope? I have the same questions as @Porc. What will the receiving infrastructure consist of to receive from the aircraft?
Did the NPRM mention cell towers? The parts I skimmed didn’t mention that. It would make sense to leverage existing deployed cell infra. But they don’t say that. And while they mention cost for USS subscription, they don’t mention a cellular account or line fee.This "aero scope" isn't something I have seen or used (although I have seen it mentioned in other discussions). How does it work? Would it qualify for the "standard" option of broadcasting from the drone? Or, does it send the data back just to the controller? If the latter, it could only qualify for the "limited" option.
Although, I do think that's a ridiculous requirement of the FAA... the way I see it is they are giving 2 options:
1. Standard: Broadcasts from drone to cell towers.
2. Limited: Broadcasts from controller to cell towers.
Both still require a data connection to the same towers, it's just that the standard option is more costly to implement (requires additional hardware and a subscription service to access the cell network). If the controller is connected to the drone, and the drone sends GPS info back to the controller, why can't the limited option also be the standard option as long as the controller is connected to the drone? The standard option only seems useful for true autonomous operation, such as what Amazon drone deliveries might do.
It sends the ID over WiFi. I have read where DJI says anybody with their app could pick up your drones location and ID. It doesn’t require the expensive AeroScope units that airports have, it goes over the WiFi and transits location etc.
I had a big initial investment (drone, I Pad and a new computer that will handle the videos and editing and getting my part 107 license), I do intend to expand my equipment however not nearly at the rate you suggest. That being said I am relativity new to the drone industry and do not understand all the ins and outs. It just sounded quite ominous from what I read.You're worried over something that is still very much in it's infancy. It's gong to take time to get the regs worked out and odds are it won't be finalized in it's current form. After that time the infrastructure will have to be built and installed.
I tend to agree with BigA that it’s not likely to be implemented in its current form. Indeed half my brain thinks it seems so overreaching that it seems like it could collapse under its own weight. The other half of my brain is more jaded at this age. . I feel that could be no limit to what the bureaucrats pass and how much control, big brother regs and unfunded mandates they want to foist on the citizenry. ESP the unelected ones that aren’t directly accountable to the ballot box. So while it may not be implemented in its current written form, it doesn’t mean that the worst parts don’t stay in.You're worried over something that is still very much in it's infancy. It's gong to take time to get the regs worked out and odds are it won't be finalized in it's current form. After that time the infrastructure will have to be built and installed.
