Enabling max distance?
I have a P3S and was just curious what happens when I turn on (enabling max distance). Does it change the range? Someone please explain in detail. Thanks
When enabled, you'll be able to enter the max distance you want your Phantom to be able to travel. If disabled (and you're not in Beginner Mode), you'll be able to fly until the remote controller signal is lost.
It enables you to fly to the limit of your signal strength and overrides any previous distance setting you have entered. Your altitude, interference free area and antenna orientation are important if you want to get the best out of your PS3.
After enabling it, you can set the range from 15m to 500m from home point. It'll warn you with a message "Maximum distance reached" when you reach the set distance and you are not allowed to fly further away.
