Yeah, that is how gearbest is. But it looks pretty self explanatory in the pictures.
I'm afraid it doesn't explain much for me, such as how does one hook up the 2nd battery.
Doesn't seem like for the extra time it's offering that it's worth it for all the weight and trouble of the mod! You can strap on some light maxamps and get that much extra time without even knowing the batteries are on there[emoji41]
Hey db, did you see the pm I sent you
I think ...No need Battery Holder Tray....but Jimbal plate useful for can passible move carmera to forward so we can use 6600 with stably...6600 will be in all most center. Maybe I'll order.Doesn't seem like for the extra time it's offering that it's worth it for all the weight and trouble of the mod! You can strap on some light maxamps and get that much extra time without even knowing the batteries are on there[emoji41]
Yep. I responded[emoji41]
Hey db, I should be getting my gold sunhans tomorrow. I don't use a tripod for my setup, I got a secraft tray
My intention is to Velcro the amps on either side of the panel cable connections and the battery at the bottom center of the panel. Do you think this will cause any interference with panel signals?
Thanks
Btw pm me your address so I can send you the camera
No the amps on the outside no matter where you put them shouldn't cause any interference, unless it's in front of the antenna of course
How to connect xt 60 and power connector of rf amp ?View attachment 59018
You could even Velcro, tape, or glue your amps directly to the back of your panel to save space
I am thinking of this. But when I tried to run 2 DJI battery's ,I mounted one under the VSP sensor and I crashed at 20,000ft .And that bird is gone.Hey db, did you see the pm I sent you
I don't understand about your crash because 2 DJI battery are about 8,800mah..... what's the matter with your battery?I am thinking of this. But when I tried to run 2 DJI battery's ,I mounted one under the VSP sensor and I crashed at 20,000ft .And that bird is gone.
It was my fault, I did not monitor the battery volts right. So I am in shock. DB. Is the battery guru here, I would trust anything he say.
It will be some time before I try to go far again.
Yes! I have a blue 12v batterie. Just one blue 12v okey for 2 rf amp?I use the blue 12 V batteries and I have never used a normal lipo, but it would be as simple as soldering a lead wire together with the proper ends on it
If your amps are 12V.Yes! I have a blue 12v batterie. Just one blue 12v okey for 2 rf amp?
I wish I new, but that bird is gone cant get it back.I don't understand about your crash because 2 DJI battery are about 8,800mah..... what's the matter with your battery?
1C is 2.3Amps I charge at 3.5amps works fine!!!What is mean 1C?
