Place the gimbal in Follow mode and not FPV. That should clear things up for you so you can really enjoy your weekend.
Thanks, I'll give that a try. Where do I find that setting?Place the gimbal in Follow mode and not FPV. That should clear things up for you so you can really enjoy your weekend.
Frank, when I put mine in FPV, the screen tilts fast and hard to the left and right when I roll left and right, not when yawing. His does it slowly when yawing.
Did you get the setting changed?
What do you mean Frank? I changed it to FPV and the screen tilts fast and hard so I changed it back to Follow.
So both of you have two different types of issues going on. The THH craft is more of a common situation and likely no malfunction taking place. If anything a few tweaks in the settings. I don't think you are taking the constant wind blowing at your higher altitudes. If you want to compare the A/C's characteristics, You can stand behind the A/C with pointing whatever direction you begin with and do your simple roll checks. The fly the A/C to the opposite side from where you are standing and do the same comparison test.
And on DennyBoBenny's A/C, this in my opinion is a mechanical issue. I would want to look at the flight log data on the .txt file ONLY if the A/C has GO app version 2.8.3 or lower. If it doesn't have that version, there is 2 options. 1st option is to delete the current GO app and install a fresh copy of v2.8.3. Or.....
Upload the .dat flight log file and place it in your dropbox public folder and copy the public lonk and pasted it here to be diagnosed.
Here is the .dat file link: Dropbox - FLY012.DAT
I just now downloaded your file. I have another in front of you I hope to get finished this evening. I will get with you as I may have a question at some point. Hang in there.
Btw, I also re read where I mentioned deleting the GO app and installing 2.8.3 to send a usable copy of the txt file. That is bad info and not correct. The A/C would need 2.8.3 prior to the flight, and then everything would be good as gold.
Hey DennyBoBenny- I got a visit from the man with a bag of trix and I now have the necessary tools to view your TXT file. I would appreciate it if you would take the time to upload here when you get the chance. Thanks!
Btw, I want to compare the info to your DAT file I already have.
Frank, I'm not in a hurry so take your time. I really appreciate you taking time out of your day help me. Here's the link to what I hope is the correct .txt file. If it's not, or if you need anything else let me know. Dropbox - DJIFlightRecord_2016-08-18_[18-03-35].txt
