It's those guys with the black drones that give us other guys a bad rap.Thought I would share..
Looks to me like a 3DR Solo..
<snort>
The shorting is a bit of a myth, like peeing on an electric fence. The water droplets are too far apart to cause a short. In air, every 1000v can only jump 1mm, so if you have 1000 droplets, spread out between the wires, and 1mm between them, it will take 1,000,000v for it to flash over. Mind you, I haven't tried the electric fence, but they are limited to 5kv and 10 joules of energy. However, if it happened, it would surely change your point of view.Thought I would share..
Crazy as it seems, Myth Busters actually tried that! Actually they used an artificial 'urinary treack', but they did confirm that the stream starts to break up almost immediately causing exactly the condition Peter described. Even in the daytime, keeping proper perspective on the position of a bird and obstacles like tree branches and power lines can be difficult. I'd like to see the video from the bird, wonder if the pilot flew directly into the wires or lost SA and hit one while maneuvering? Someone earlier mentioned that it might be a fly away, but in any case, looks like an area where flying at night probably wasn't the smartest thing to do.The shorting is a bit of a myth, like peeing on an electric fence. The water droplets are too far apart to cause a short. In air, every 1000v can only jump 1mm, so if you have 1000 droplets, spread out between the wires, and 1mm between them, it will take 1,000,000v for it to flash over. Mind you, I haven't tried the electric fence, but they are limited to 5kv and 10 joules of energy. However, if it happened, it would surely change your point of view.
