Drone Stuck In Powerlines at Train Station.
Discussion in 'News' started by Blue Bird, Apr 10, 2016.
  1. Blue Bird
    Dade County, Florida
    Thought I would share..
    Looks to me like a 3DR Solo..
  2. flpholt
    palm harbor florida
    yep it probably lost signal and flew away
  3. Blue Bird
    According to the news, They could not get it down for an hour or so. They finally had to get a boom truck and take it down by hand.
    Amazing that it wasn't shorting out from the water blast. Looks like it was stuck by the gimbal.
  4. GoodnNuff
    Washington State
    One of the dangers of night flying - power lines are invisible in the dark.
    This happened here in Seattle last year with an Inspire, but it was hung up 150 feet above Lake Union (over water). It cost the power company $35,000 to remove it using a crane on a barge. Not sure if they ever found the owner so they could hold him financially responsible.
  5. Air Ontario
    U.S./ Canada
    It's those guys with the black drones that give us other guys a bad rap.
    <snort>
  6. DroneDestination
    :tearsofjoy::tearsofjoy: This is why 3DR Solos are garbage.
  7. peter west nz
    The shorting is a bit of a myth, like peeing on an electric fence. The water droplets are too far apart to cause a short. In air, every 1000v can only jump 1mm, so if you have 1000 droplets, spread out between the wires, and 1mm between them, it will take 1,000,000v for it to flash over. Mind you, I haven't tried the electric fence, but they are limited to 5kv and 10 joules of energy. However, if it happened, it would surely change your point of view.
    jeepacation likes this.
  8. Richard R
    Ohio
    Crazy as it seems, Myth Busters actually tried that! Actually they used an artificial 'urinary treack', but they did confirm that the stream starts to break up almost immediately causing exactly the condition Peter described. Even in the daytime, keeping proper perspective on the position of a bird and obstacles like tree branches and power lines can be difficult. I'd like to see the video from the bird, wonder if the pilot flew directly into the wires or lost SA and hit one while maneuvering? Someone earlier mentioned that it might be a fly away, but in any case, looks like an area where flying at night probably wasn't the smartest thing to do.
  9. a31burgervan
    Was it black before it hit the cable??
  10. GMack
    I've seen them use water to wash the insulators on the high tension lines. More fun is to watch the guy who wears the mesh suit get dropped onto the line from a helicopter and the blue flash or arc that goes from the line to his gloved hand when he first hooks onto the 40KV line to crawl around on it.
    My electrician works doing that mesh suit stuff and I think he's nuts. He said the power company hires him out as they don't have anyone who wants to do it. In LA they will have a second helicopter as backup to the one who drops the guy onto the lines. Interesting to watch them work. He says that static you hear on the radio is some arcing buildup that forms like little volcanoes on top of the lines and he has to scrub it off by hand if it can't be hosed off. Some people's jobs they can have.
Similar Threads - Drone Stuck Powerlines Forum Date
Anyone stuck a 360 camera to their drone? General Discussion Jul 28, 2017
My drone repair is stuck at "To be Received" Standard/4k Discussion Apr 18, 2017
Drone stuck in 125 ft tree Pro/Adv Discussion Apr 2, 2017
Drone stuck in tree Pro/Adv Discussion Jan 28, 2017
Worth $150 to retrieve stuck drone? General Discussion Jan 23, 2017
