Hello. I changed the base on my drone(failed landing). The replacement was successful. A new problem has just appeared. Now the compasses are always in the red zone. Calibration does not help. In flight, a compass error appears and the drone enters atti mode. I don’t understand anything. Help deal with the problem
What do you mean by "changed the base"? Did you replace the two landing gear legs and/or the bottom shell?
What happens if you attempt a compass calibration? Have you tried an IMU calibration? I ask if you have tried these procedures because the incident may have caused other component failures internally.
If you have tried the compass calibration outdoors without any metal in the vicinity and it fails, then you most likely have internal damage in your drone.
