Does VPS need to be turned off over the ocean
If so, where do you turn it off on the GoApp?
Yes but for some reason they pulled that functionality away from us.
If you fly in A-mode, VPS will still be enabled, but it won't attempt to control the Phantom's position. That's the best we can do until DJI allows it to be disabled from DJI GO.
It generally should not cause any problems if you're not flying close to the water. For the Phantom 4, that means you should be flying more than 10 meters above the ground/water (since that's the effective range).
rockymountaincaptures
