DJI Vision White SCREEN of death Help
I need to rebind my wifi extender with my P2V+. But the DJI Vision app wont work. When input my user name and pass code the app goes to a white screen and then closes on it's own or say "DJI VISION ISN'T RESPONDING". I have not used he in a few months and don't know whats going on. Some one please help me out. Whats going on here. Did DJI remove access to the app? How can i rebind the camera to the extender without the app. :(:(
03/03/2018
Thanks Sabastian87 for responding to my questions. Your assistance is greatly appreciated. I'll let you know if an update fixed the problem shortly. I found a work around in the mean time... I used lucky patcher to MOD the original DJI VISION APK. Now I no longer have to log in online first to gain access the app. The trick is to install the original apk and not give it access to wifi via blocking.Then use lucky patcher modify the apk by manually adding that the app has already registered. If you do not do this the app will always check to see if your registered before giving access to the app.
03/03/2018
Further update. This issue only happens on my Samsung S6. The app works on the following tablets without any modification needed.
1. Nvidia Shield Tablet
2. Google Nexus 7 old and new
03/03/2018
I am doing a complete wipe of my S6 right now, to double check. I'll let you all know shortly
Welcome.
I’m not specialist and I’m not using vision app as I have phantom4.
I just had the same problem with other apps when was avoiding updates of my ISO :)
Good luck my friend and hope you will fix your problem.
I'm going use my NVIDIA Shield Tablet with my P2V+ V3 Stage 3, Because It's jail broken and does not require any updates The app works great on it no flaws. Here's a few pictures of a Scary Movie I"m shooting with it.
I love my P2V+
hcashmore11
