Dji phantom flight
Something new I found by accident, place your first waypoint then hold your finger in another part of the map for a couple of seconds and it will do a sort of poi mode, then you can add more waypoints away from it. It seems you can only do this with the first waypoint. Will try it out tomorrow
Something new I found by accident, place your first waypoint then hold your finger in another part of the map for a couple of seconds and it will do a sort of poi mode, then you can add more waypoints away from it. It seems you can only do this with the first waypoint. Will try it out tomorrowView attachment 32154
Interested in knowing if the POI worked...
Looks like it does work under iOS 9 , it had reset it self and I had to pick the quod to use, but all works well
Reactions: bobmyers
billyboy02
