Dji phantom 3 standard camera to gimbal problem
k
Obviously, you need to reattach the parts properly with screws.
Are you sure that the screws are not still in the housing? It appears as though I can see the tip of a screw in the picture.
Hi!
Yes all other scerws is left there but one was missing... But do you think that i maybe can screw them back someway, like opening the back or something or do i REALY need to send it back to dji? Thanks for the answer!
If it were mine, I would not even consider sending it anywhere to put some screws back in, but I'm not you, and cannot say that it is within your abilities.
That being said, why not just carefully take the rear cover off. And see if you can put the screws back in?
Also, someone else here may be able to assist you in determining the specs on the screws so that you can obtain a replacement screw for the one that's missing.
Reactions: Mark The Droner
DJIlvr67
