DJI no longer sells replacement batteries for the Phantom 4
The DJI Fly app is compatible with mobile devices running iOS 11.0 or higher and Android 6.0 or higher. It's designed for a simplified and intuitive user experience and is specifically used with newer DJI drones like the Mavic 3 series, Mini series, Air series, and Avata. While the older DJI Go app is compatible with devices running iOS 10.0 and Android 5.0 and above, the DJI Fly app focuses on newer hardware.
Here's a more detailed breakdown:
  • Operating System Requirements:
    • iOS: iOS 11.0 or later is required.
    • Android: Android 6.0 or later is required.
    • iOS: DJI recommends using an iPhone 11 or newer.
    • Android: DJI recommends using mainstream flagship phones released after 2019.
  • Note:
    The DJI Fly app is not compatible with older DJI drones that use the DJI Go app.
The DJI Go 4 app is compatible with a range of DJI drones, including the Mavic series, Spark, Phantom 4 series, and Inspire 2. It requires Android 5.0 or later and iOS 9.0 or later. Specific compatible devices include various Samsung, Huawei, and other Android phones, as well as iPhones and iPads.
Compatibility Details:
  • Drones:
    DJI Go 4 is primarily used with the Mavic series (Pro, 2, Air), Spark, Phantom 4 series (Advanced, Pro, Pro V2.0), and Inspire 2.
    • Android 5.0 or later.
    • iOS 9.0 or later.
Beside the app GO4 for phantom 4, can we use another app without having problems? I know some apps works depending the devices and also depending the operating systems.
The DJI GO 4 app is the primary application used to operate the DJI Phantom 4. It allows for live camera view, camera control, flight parameter adjustments, and mission planning.
DJI GO 4 Features:
  • Live View: Displays the real-time camera feed from the drone.
  • Camera Control: Adjusts camera settings like exposure, white balance, and more.
  • Flight Parameters: Allows for adjusting flight modes, speed, and other settings.
  • Mission Planning: Enables pre-planned flight paths and automated tasks.
  • Firmware Updates: Allows for updating the drone's firmware.
  • Data Management: Stores and manages flight logs and photos/videos.
Other Compatible Apps:
  • Litchi: A third-party app that offers more advanced waypoint mission capabilities.
  • DJI GS Pro: Another third-party app for more advanced mapping and surveying missions.
Note: DJI has discontinued technical support for the Phantom 4 Pro and Phantom 4 Advanced as of June 1, 2025.
****(DJI GS Pro app is for IPad) ****
COMPATIBLE PRODUCTS
Mavic 2 Enterprise, Mavic 2 Pro, Mavic 2 Zoom, Mavic Pro, Phantom 3 Standard/4K/Advanced/Professional, Phantom 4/Pro, and Zenmuse X3, X5, X5R, X4S,X5S, Z3, Z30, XT, XT2 and Mavic 2 Enterprise Dual.
Reactions: Carlos S.
  • Note:
  • Drones:
    • iOS 9.0 or later.
Thank u for that in depth reply. I have read some of that before and checked my phone and iPad. Should be good to go. I cleared all my warnings and it started working again for a short time, then kicked me off again. It keeps saying I need to download firmware for precise location. And to connect drone via cable to something just had a diagram. And if I hit ignore, that's when it kicked me out about 3or4 minutes into operation. Any ideas??
Is the app requesting an update for the app,.......or the drone?
Sometimes app versions and drone firmware versions are mismatched and cause issues..........plus, if the cable from the device to the R/C isn't a very high quality data transfer cable it will cause issues.
Strange that it is saying to '....download firmware for a precise location......' and kicks you off. Have never seen that warning before.
Maybe delete the app and do a clean re-install.....?
The precise location, also shows to me and hit ignore, this is to update the restrictions areas like airports, landing zones, but don’t affect the flight. (in my case) because the restrictions countries are different. But if you are inside some restrictions areas, the drone gives warnings and sometimes doesn’t takeoff. If you have more restrictions areas updated, means less areas to flight. The update it’s by internet with the device connected. Because the update it’s for the app and the drone separate. And the names shows in the app DJO GO4: PRECISE FLY SAFE DATABASE (for Aircraft) and PRECISE FLY SAFE DATABASE (for app) and the last one BASIC FLY SAFE DATABASE. Maybe here it’s your problems, because you clear all warnings, works short time and issues again when collecting the warnings. Maybe you can use your drone without internet and don’t update the fly safe database. Or go to another location, out of the restrictions areas. Also you can check the restrictions areas with other app like UAV forecast to check if you are inside the restrictions areas.
@sansuciboy1 , which Phantom 4 model do you have? ie, Advanced, Pro, ProV2.0, or Phantom 4 RTK.......or the 'Standard'....?
....and I'd guess you are not in the US, right..?
** I need to research this compatibility issue a bit further, but need to know Drone model and your 'general' location, the US or across the big pond.....***
Russianman92
