Dji hdmi output module problems
Has anyone else had any problems with there phantom 4 after installing a new dji hdmi output module? It's causing image transmission static on any device or app that I use. I did update my transmitter after installing the module and I have noticed from looking at other videos on YouTube that the inside of my module is copper coated and the ones I've seen people installing were not like that.
Is the module a genuine dji #54 part? If so, you may have to check that the three ribbon cables are in place and secured properly with the retaining clips and the module cover is snug and firmly screwed in place. I had a similar issue and after removing the module and checking it a couple of thousand times, it turned out to be the rubbish HDMI cable that came with my goggles. I purchased a quality cable and the problem largely went away. I have read of a bad batch of genuine modules and people downgrading/upgrading the firmware in the control to get it sorted as well.
