DJI Goggles - Immersive FPV Aerial Video Goggles
Los Angeles, CA
Good morning from NAB here in Las Vegas!
After an awesome event last night at the Wynn with exciting new releases from DJI including the Ronin 2, CrystalSky Monitors, Cendence Remote Controller, and Tracktenna -- this morning we are happy to announce the release of DJI's first FPV glasses/goggles, the DJI Goggles.
DJI Goggles are comfortable goggles designed for seamless FPV flying with DJI products. They combine a pair of large ultra-high quality screens, long-range, low lag wireless connectivity, and direct control of photo and video capture.
Low Lag Transmission
DJI Goggles are able to offer both 720p/60fps and close range 1080p/30fps with an extremely low latency of just 110ms.
High Quality Optics
Each screen packs its pixels together tightly so you see a clean, cohesive image with no latticing.
Head Tracking
Your head movements control both the aircraft yaw and camera tilt in Head Tracking Flight mode as with the remote controller sticks.
Touchpad & Remote Controller
Access to key intelligent features through a touchpad integrated into the DJI Goggles.
Compatibility: DJI Goggles supports Mavic Pro, Phantom 4 series and Inspire series. Some functions will be adapted for different DJI Products.
Availability: Late May (All May pre-orders are now sold out, new pre-orders are estimated for fulfillment in June) - Updated 4/25/17 10am PST
Price: $449
Now Available for Pre-Order
DJI Goggles – Immersive FPV Video Glasses
DJI Goggles Specs
Weight
Goggles: 495 g
Headband: 500 g
Goggles: 195×155×110 mm
Headband(Folded): 255×205×92 mm
FOV
85° (single screen)
Screen Size
5 inch×2
Interpupillary Distance Range
58 – 70 mm
Refresh rate
60 Hz
Screen Resolution
3840×1080 (single screen: 1920×1080)
Operating Frequency
2.4 GHz
Max.Transmission Distance
Same as the aircraft connected
Video Downlink Resolution
1080p 30, 720p 60, 720p 30
Video Downlink Latency at least
(Near field and free of interference)
110 ms (Mavic Pro, 720p60, video format: 720p120) 150 ms (Phantom 4 series, 720p60, video format: 720p60/720p120)
140 ms (Inspire 2+X5S, 720p60, video format: 1080p120)
190 ms (Inspire 2+X4S, 720p60, video format: 1080p60)
Battery Capacity
9440 mAh
Battery Energy
35.44 Wh
Max Operating Time
6 hrs
Operating Temperature Range
32°F (0°C) - 104°F (40°C)
I/O Interface
Micro USB, 3.5mm audio jack,
HDMI type-D, Micro SD card slot
HDMI Supported
HDMI 1.4b, HDCP 1.4
Sensors
Gyroscope, Accelerometer, Proximity sensor
Charger
Input: 100-240VAC, 50/60 Hz. 0.5A
Output: 5V,3A ; 9V,2A;12V,1.5A
With Mavic these are wireless, no physical connection is required to the RC, correct?
What about Phantom and Inspire series? Are they wireless, or do they need an HDMI cable connected to the RC?
Wireless for the mavic but USB for 4 series to get the head pan feature or hdmi for just fpv.
To bad they are leaving the phantom 3 standard unsupported. I tried the cheap vr method and was hoping these goggles worked with the phantom 3 standard.
anxiously awaiting some reviews
jeetbuzz360
