Just update the dji go app on Android to 2.4.2, what a mess, the app crash when I check my flight records is a total mess
Wow you are right. I tried running Go and if I went straight to the flight record menu, it crashed. Tapping on Me then back to Equipment, before going into flight record menu prevents the crash. Good observation.Ok I found a solution that works pretty good, in order to prevent the app from crashing, press on the "Me" icon and then go back to "equipment" and from there you can access the flight record without any error, works fine for me. I know it is a bit annoying but a least pepole that experiencing this problem can avoid the app from crashing at least until DJI will fix this bug (I hope they will :/ ). Btw you only have to do it once every time you running the app.
Let me know if it works for you
