DJI GO 4 Update 4.1.4 Android
If you update, you may have to wait through an AC update "Firmware Mismatch", followed by a constant beeping of the RC, with a red flashing light.
After the aircraft Update was successful, it rebooted, then connected. Going into Go 4, the red flag said, controls not calibrated. So, I went in and did that, moved the sticks and gimbal and that was fixed and the beeping stopped.
Now, there is only the "Calibrate Compass or Move the AC" warning which I will deal with out at a field, where I can calibrate the compass, knowing there is nothing to cause an anomaly, sure didn't want to do it in my hobby room. ;) I am sure this will clear as soon as I calibrate or move out of the house.
But, I suspect that the AC update removed any prior calibration, as the P4P was flying fine a day ago.
When I get a change to go out to the field, I take care of this and then see if all is well.
I will check back when I have news.:)
Ok,today, moved to a better spot, compass now normal. Update to 4.1.5 OK.
apktuti
