BlackTracer said:
skyhighdiver said:
I would not even care if it was 66 min as long as we could set a highter max
As far as I know there is no max RTH height. In other words if you are flying at 200 ft, an RTH would occur at 200 ft. It is the minimum we are talking about, no? If the bird is below 20m it will rise to 20m and RTH. I would like to be able to adjust that value.
ok I guess some don't get the point let me spell it out like a first grade teacher
I am well aware of how RTH works I use it a lot on my long long flights
I don't need lessons on how RTH works
if you are below 66 ft and it is activated it goes to 66 ft and flys home
if you are above 66f when it is activated it stays at the elevation your at and flys home
*( with new airport restrictions this may be different over the airport areas ) as that I have not done
That being said like the video showed I take off fly over the lines into a field descend down to film creek and RTH kicks in
now the 70ft power lines( OR TREE OR BUILDING,) are a death trap to my phantom
as its going to climb to 66ft and go into the 70 ft object I went over
PLEASE LET ME SET MY HEIGHT EVEN IF 66 IS MIN LET ME RAISE THE min to an appropriate height
